European Shark
riber.bentsen's Avatar
Maybe you have the wrong air filter box? There should be a short, fat pipe coming off the bottom of the pass. side intake tube (not the flexi-thingy) which should be directly above this rubber hose when you mount the box.
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 04-09-2013, 02:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
camo's Avatar
You mean from HERE?
If I'm not mistaken, that's where the OTHER hose goes, the flexible one. And that's the only place I can see on the AFB. And it's the same AFB that came off.. Sorry if I'm confusing or not getting something simple.
P.S. the cigarette butts aren't mine
"Weissach" 1982 Porsche 928 auto
Old 04-09-2013, 02:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Recovering dismantler
neil30076's Avatar
I have not seen it on the side like that, but that's where it goes, as Riber said, maybe wrong filter box.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 04-09-2013, 02:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
camo's Avatar
OK! I believe I've gotten that taken care of now, thanks to you two
New problem. I need to know how to adjust fuel pressure and idle. I'm getting 32 PSI fuel pressure and it's supposed to be 42. Any ideas?
I'll also be googling it, but i'm running out of time so I might get a quicker answer here
Old 04-09-2013, 02:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Network Native
Danglerb's Avatar
82 Ljet the fuel pressure is set by fixed regulator relative to the manifold pressure (holds the pressure across the injector constant). Idle adjust is a big screw on the front of the throttle body.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 04-09-2013, 08:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
camo's Avatar
Ok, thanks Danglerb!
Old 04-09-2013, 08:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
camo's Avatar
What is the working fuel pressure supposed to be?
Old 04-09-2013, 09:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
neil30076's Avatar
Bosch manual says 2.5 bar = 36.75 psi, so you are a little low.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-10-2013, 06:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
camo's Avatar
Ok, thanks neil.
The guy working on my car has given up. So I'm towing it to a shop to have it finished.
Everything is back together, it'll start but will not idle. It sounds GREAT when its revved up (besides sounding really rough), but it idles VERY rough and eventually dies. You can hear a huge vacuum leak, but he's checked everywhere and can't locate it.
Old 04-10-2013, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
neil30076's Avatar
Check the large O ring where the MAF plugs into the main throttle body. It probably not seated properly and leaking.
try this, take a spray bottle with water, gently mist it down towards the o-ring, if it's leaking it will suck in water fast and you will know it! Don't overdo the spray, and keep it away from the 6 pin connector on the MAF. Was the throttle body removed? That can be a big problem if not reset properly. Also spray the mist around the rubber tubes connecting the throttle body to the inlet tubes, may be a big leak there. DO NOT let someone who does not know the 928 try to fix it, you are on that slippery slope to disaster. Do you have the vacuum line diagrams and have you checked them out to be sure they are exactly correct? Use a piece of rubber tube held to you ear as a probe to listen for and pin point the leak, if it's that bad should be easy to find.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-10-2013, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Kyle C
BTW that hose for the air pump diverter valve should mount to the underside of the air filter top cover, not the lower half.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 04-10-2013, 03:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
camo's Avatar
Neil, thanks for your thorough response. We did get the MAF seated correctly (after several attempts). But I ended up having it towed to a shop as I don't have time to spend on it right now and I need it to get to school. Sadly, nobody in this area knows anything about the 928, but The shop its at has done extensive work for me before ( and my dads Corvette) and I have been happy with it. So far they've found 2-3 vacuum leaks and the guy who put my injectors back had like 2 of them seated incorrectly and a couple o-rings in wrong. something like that.
Opelotus, I was able to eventually figure that out too. But thanks just the same
Old 04-12-2013, 09:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
neil30076's Avatar
What area are of western oregon you in? There are a few good owners in OR, WA that could help, maybe i can help you find one...
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-12-2013, 10:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
camo's Avatar
Benton county.
There are actually quite a few owners I've seen around here! But haven't been able to contact any of em.
Old 04-12-2013, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
camo's Avatar
I learned something today.. The 928 is fast. I was going 25 and the speed limit changed to 35 so I "gave it some gas" and sped up to 35 (it was actually 36 but don't tell anyone), and it put me back in my seat. Of course there's only so much you can do in a lot of traffic, I'll have to take it out somewhere and really push it.
Got it back from the shop about 4:30 and it turns out the guy doing the work for me previously had seated 3 injectors incorrectly and there were a couple vacuum leaks. Then when that was all fixed the brake lights wouldn't work so we replaced the switch, then my stupid "Brake pr. (!)" light came on again and the sensors the guy replaced a couple a months ago were once again completely severed. So i'll be suffering with those stupid flashing lights until I have the chance to replace them again. Or I can just disconnect my battery for a few minutes every day.
Anyway, the thing runs AMAZINGLY! It sounds (and feels) so great when it accelerates. However, it was really rough when I started it at nine after a three hour class. But i can live with that being that it clears up pretty quick.
Old 04-15-2013, 09:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
camo's Avatar
Anyone know how long/hard to replace brake wear sensor? Maybe where I can get instructions?
I gotta do it tomorrow and have a VERY limited amount of time to do it.
Old 05-02-2013, 09:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
MPDano's Avatar
After removing your wheel. About 2 minutes.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-03-2013, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
harborman's Avatar
If you are very careful you can remove the sensors without breaking. I put a little PB Blaster on them, then used a small screw driver and gently pried them out. After installing the new pads, I cleaned the sensors and pushed them back in the new pads. Make sure you clean the rotors of any oils.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-03-2013, 06:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
camo's Avatar
Hah, OK thanks guys. I just replaced both and one is broken again. Pelican parts sent me one and they're waiting on a picture.
Old 05-03-2013, 09:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
MPDano's Avatar
Yes, very easy to break when removing and installing. Maybe a little diaelctric grease to get it to slide in easier.
Old 05-03-2013, 11:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
