Wipers stopped working?
'86 928, no wipers, checked connector under cowling and cleaned...still nothing - nada, the washer motor comes on when you pull the stalk back, but nothing else - any common gremlins that I should check first? thanks, frank
check the fuses after that you should pull the motor out and take it apart and clean it,
its prolly rusted inside then fit a cowl cover, Jerry Feather makes new cowl covers |
After you check the fuses, check to make sure that the arms from the motor to the wipers move freely. It could be that they have not been used in a while and merely require some lubricant and a little time to run after being freed up.
couldn't find a fuse in the passenger footwell and I have a fuse diagram - there is a relay there, which I pulled and reset....where do they hide the fuse?
Never Mind...found it #5
| All times are GMT -8. The time now is 10:35 PM. |
