Kool
AirtekHVAC's Avatar
Front ball cup replacement was like 15-20$, a newer version of the entire front assembly is out, but I think it is like 60$, and the rear coupler I think is around 65$....
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 02-24-2013, 04:45 AM
Okay cool I will have to deal with that.
Old 02-24-2013, 10:14 PM
okazy I have a part question!!!! What is this thingy!!????
Mainly the black thing it mounts on the starbard side of the engine (left side when looking at engine bay) between the first sand second cylinder intake legs
Old 02-27-2013, 04:36 PM
Just making notes on relay part notes.
Headlight power Relay 928.615.127.00
Flashers 1H0.953.227
Fog Lights 928.615.117.02
High/Low Headlights 928.615.123.00 (whats the difference)
Now My headlights go up and all then the lower ones turn on and least the outside ones and the running, and the flashers work but not well. eather way neither in bright or regular mode to my moving headlights work, they might be disconnected... where is the connection, their is a plug off on the bottom of the radiator and its to a tube thingy by the headlight motor.???
Old 02-28-2013, 03:19 PM
Kool
AirtekHVAC's Avatar
Jack...this should help you out!
Contact Brian (Medipedicman)..he might have one to sell....
Ron
Old 02-28-2013, 05:45 PM
Kool
AirtekHVAC's Avatar
oops...forgot the pic...DUH!
Ron
Old 02-28-2013, 05:47 PM
Well now I'm stuck I have a hard decision betweenn repairing my Mercedes 190e I just damaged or rushing the both need 300$ at least. Both still .
Old 03-01-2013, 08:01 PM
Well here is the damage...
Old 03-07-2013, 03:05 PM
So i decided to test the fuel pump today, put a volt tester on it... bad relay.... well on the bright side i straight attached the bat to the pump and it worked perfectly.... minus theere not being an intake in the car at all im happy with the outcome i need only a relay now.
Old 03-13-2013, 08:49 PM
Coil over adjustables suspension standard?
Old 03-14-2013, 03:05 PM
Hello So i finally saved up money needed, .... and got a ticket... but I bought the fuel pump relay and hopefulley it will get the pump to work, also this or next weekend after the pump arrives i will order the gaskets and be on my way.
1979, 928 US, engine in progress.
Old 04-02-2013, 02:27 PM
MPDano's Avatar
All you need is a piece of wire and two spades to make sure the fuel pump works. Plus, isn't there other relays of the same type in your CE Panel?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-02-2013, 02:47 PM
Well i feel special now.... which ones??? also i got it for 20$ not a big loss
Old 04-02-2013, 03:08 PM
MPDano's Avatar
Here's your chart. Print it out and keep in your glovebox.
https://www.928gt.com/t-7879fuse.aspx
Old 04-02-2013, 03:14 PM
also which slots can i jump to get it to work, i took a battery directly to the pump and it worked perfectly, but I want to make sure the actual plug works so i dont have too many electrical issues.
MPDano's Avatar
found this by googling.
JUMPING THE FUEL PUMP RELAY
Old 04-02-2013, 03:24 PM
awsome, jumped, and the socket works.
Old 04-03-2013, 12:01 AM
laneyamps's Avatar
Nice project, BTW...good luck with it!
And, just to add my 2c, if for some strange reason, you can't find what you need here at Pelican, 928GT, or 928srus, etc etc, check out www.dcauto.com for parts. It's a Porsche junkyard. They have come through for me, a few times. And they're very easy to deal with.
84' 928S Black/Black
Old 04-03-2013, 09:31 PM
awsome thank you i have been to the shop before nice poeple
Old 04-04-2013, 01:22 PM
i will sell it to the first person with 2600$
Old 04-14-2013, 08:44 PM
