'79 928 Euro 5 Speed
'79 brake bleeder removal
I broke off the top of the bleeder on the front right caliper trying to bleed it. The caliper is old, but still in good condition and I have no reason to buy another one without at least attempting to fix this one. It is just my nature. Has anyone had any luck removing the stuck bleeder? What tips would you have for doing this? It has basically broke flush with the casting where they normally snap.
'79 Porsche 928, '00 Porsche Boxster, '86 Porsche 944, '04 BMW Z4 '77 Fiat Spider 124,'07 Chevy Suburban LTZ '83 Jeep CJ7, '06 Harley Sportster |
Kool
Should be able to put an easy out or reverse drill bit into what's left of it....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Petie3rd
BUT before you do,
get a MAPP gas torch and heat the area around the bleeder then spray some PB or Kroil into the bleeder, let it sit, do this a few times heating and spraying over the course of a few days. NOTE you dont need to get the caliper/bleeder super hot around 300 F should do, an IR gun works well here. after this get your tools in order an easy out and reverse drill bit . Heat the caliper again and drill the bleeder with your reverse DB, then fit the easyout and tap it a few times then try to unscrew it, hopefully it will come loose, have another bleeder handy so you fill the vacant hole
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
