-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   86 air conditioning problem (http://forums.pelicanparts.com/showthread.php?t=751115)
lukerman 05-20-2013 07:40 PM
compressor is working after i wired around just to make sure it is functional. I am sure it turned off due to low freon. I went to install r12 and negative vac immediately on gauge. Where is the most probable place for obstruction in line? I assume that has to be the issue. any thoughts. thanks.
Danglerb 05-20-2013 10:53 PM
Maybe orifice tube or expansion valve, usually I like my AC to be reliable, so I have the system flushed, replace the orifice tube and receiver dryer, pull a strong vacuum a few hours to check for leaks, then refill.
Mrmerlin 05-21-2013 06:36 PM
usually the receiver drier gets corroded internally and then plugs,
NOTE if your going to flush the system then do it before you replace any of the O rings then make sure the system is chemical free before installing the new O rings as the chemicals will distort the the O rings and they will leak soon after they are fitted
