Soldering Iron Recommendations for 14 Pin
Any recommendations for buying a soldering iron to solder new wires to the 14 pin? I have one, but it is not hot enough. Thought about using a propane torch on a low setting but had reservations about that. I will be rebuilding the front engine harness with new wires.
Thanks, Pete
1983 Porsche 928s US Auto |
Recovering dismantler
I use one of these, solder the pins on before you insert them in the casing, or it ( the plastic part) will melt on you!
RadioShack Dual-Heat Soldering Gun with Light : Soldering Tools & Supplies | RadioShack.com I used it on my main harness remake, worked perfectly.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach Last edited by neil30076; 07-24-2013 at 08:11 AM.. |
Yeah, what Neil is showing are great Irons. I have an old school Weller Brand one. Those garbage low watt ones don't get hot enough and also take too long to get to their max temp as well.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
I prefer a soldering station type with temp control and cleaning sponge. I also have a 47 watt pencil type. You want to apply heat fast and not keep the iron on the joint melting insulation. Also, avoid "cold solder connections" and use a good quality solder with flux in it for electrical connections.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
PS. I would not use a propane torch with flame near any gas or potential fumes from the engine. Keep a fire extinguisher near by at all times when doing any work on your car.
928: Serial Enabler
I use a benzomatic torch. Rosin flux, mid sized electrical solder.
Heat the old lugs holding them with a pair of pliers, then sling them downwards to expunge old solder. Toughest part is getting the new wires to all fit in the new (or old) 14 pin without splitting it. I don't care if the car burns up. I like using the torch. Last edited by Landseer; 07-24-2013 at 05:57 PM.. |
