1980 Porsche 928
No pressure after cleaning M/C and dividers
I pulled the master cylinder and dividers out my 928 and attempted to clean everything out (because brakes were locking Up) I put everything back together and now I can't get any pressure when bleeding the brakes. What did I do wrong?
Old 08-02-2013, 03:18 PM
needs new tires. Again.
fraggle's Avatar
Maybe the locking problem was related some some other massive failsure relate to the master and it's done.
'87 928S4 5spd - Owner
'85 930 EURO - Caretaker
Old 08-02-2013, 04:26 PM
What's Facebook?
turborat's Avatar
Lets start with your procedure to bleed brakes. Did you bench bleed the mc? Did you take the mc apart? Seals replaced.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 08-02-2013, 06:29 PM
1980 Porsche 928
I bench bled the MC as best I could ( think I may have messed it up putting it back on) does it have to be perfectly bench bled or can you still get the air out from bleeding from bleeder screws? ,also I did not replace the seals because it is fairly new, about a month.
Old 08-02-2013, 09:31 PM
1980 Porsche 928
Master cylinder is brand new.
Old 08-02-2013, 09:34 PM
1980 Porsche 928
What are the signs of a bad brake booster? I did pull the line but I did not plug it so it was still sucking air.
Old 08-02-2013, 09:35 PM
