(Sorry it says 84 in the topic, it's an 83!)
Hello all, Been googling a fair bit before posting this since I didn't want to bother people with something obvious, but I'll be damned if I cannot determine this for sure: does an 83 S Euro have the "green wire" or not? Also, dependent or independent on the above, my tach has quit working entirely; for some time it would fire up after 10-15 minutes of driving and work fine. Printed circuit foil for sure, or are there simpler things to check before pulling out the gauge pod? Thanks in advance!
-------- 1983 Euro 928S, ported/polished heads, slightly wilder cams, custom headers and a few more odds and ends |
Recovering dismantler
83 euro is a M28/ 11 or 12 engine, K-Jetronic. One distributor - green wire' comes off rear of distributor as you look at it from the front, across the bar to the Bosch control box under the 14 pin and jump post on the left side.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Petie3rd
the 83 does have a green wire
The pod/tach issue is probably the pins on the back of the tach unit not making good contact, not the push on wire connectors, but they could also be cleaned with a pink eraser
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Network Native
What? The tach works in some cars?
