1984 porsche 928S rearend sways
I have a 84' 928S 5 speed manual and when I hit the gas the rearend sways. Does anyone have any idea what would cause this?
Porsche 928 Fanatic!
Going out on a limb here, but rear shocks and/or swaybar bushings?
Webmaster - www.GreatWhite928.com 250+ 928s for sale at all times! |
928: Serial Enabler
Something very loose.
Can be front or back. Try checking torque of front lower a-arm bolts. I had an 84 where the front drivers lower a-arm bolts backed out pretty far. Felt like the rear of car was on ice. Getting off I95 south, just below Richmond, on a long right sweeping exit ramp it felt like the car was going to swap ends. In rear, check the mounting bolts for the rear crossmember. Check, front and rear, the camber/caster/toe eccentrics. Could have one loose and the setting is sliding around.
84,85,86 928 cars Last edited by Landseer; 12-18-2013 at 04:54 PM.. |
A Wrench
Check the torque on the main suspension pin, each end has a 22mm nut and when this is loose the feeling is exactly as you describe. Unless your wheel bearings are shot as that will have similar effect but you typically will have some audible issues also.
'88 Supercharged and lots of other fun stuff. |
Ok thanks guys Ill definitely all of those. This is my 1st porsche that ive owned and ive got $3, 000 to put in it right now. Being a porsche thats not going to go far. The car sat for a few yrs being driven a few times a year. Mechanically it in great shap it just needs some odds and ends. For what I got it for I wont have maybe $5,000 in it if unless god hates me!!
But it does feel like its trying to go sideways when I hit the throttle normally. Was thinking something in the swaybar but after reading everyones ideas ill definitely check out everything posted for sure.
Believe me, I've been tempted, but didn't. I think I left the Stepson undone for a night and came back the next day after using up my curse vocabulary and calling it everything but a child of god. It went right together the next day.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Petie3rd
After checking the lower link pins then you want to check the lower rear control arm eccentrics these get torqued to 140 ft/lbs and are usually loose.
Your clue they are loose will be polished areas as the eccentrics will be sliding back and forth in the slots. if they are tight then the bushings that the bolts go through should be replaced if all of the other parts have been checked
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Hell yeah thanks everyone!! I like you porsche guys already sounds like you know your stuff. Ive restored alot of classics and im only 29 but never had one with a unibody and a transaxle but im definitely liking it so far.
So if everything is torqued to spec and I want to replace the bushings then who sells them? I looked on this site but haven't found them yet
Nevermind I finally found the bushings but one more question. I have I believe stock adjustable shocks and my question is can you rebuild them or not?
Petie3rd
buy a new set of Bilstiens and be done with the shock program
Network Native
End of year half price sale going on at 928 International |Porsche 928 Parts | New, Used and Rebuilt for used parts. I was digging around in a box full on Monday looking for other stuff.
Good that you have a budget for fixing, don't spend it easily. |
Network Native
Bilstein rebuilds their own shocks, free for life if you bought them retail through an authorized dealer, but reasonably priced otherwise, used to be around $80 including return shipping, but rebuilts have no warranty.
Sometimes I drive right by Bilstein right off Scripps Poway Pkwy. I tried at one time to buy direct from there and they wouldn't have it.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
So is blistein the best shocks you can buy for taking tight curves at high speeds? If I wanted to get some extra torque and hp what would be the best route. Say i wanted 300+hp and 330ftlb of torque. Ive already got headers but have no idea if anything has been done to the engine.
I own a 1979 T/A and this car definitely has some balls but i want more out of it. Cant find cold air intakes, super chips or ??
The Bilstein/Eibach Spring combo is for sure tight. I run this combo on my Euro and for sure stays more flat on turns. The question "best shocks" will always be subjective and some will say stock shocks/Eibach, some will say Koni shocks/stock springs. Same goes for asking oil weight.
IMHO, I think the Bilstein/Eibach combo is awesome but I like the feel of a track car. It's really what "you" like.
A Wrench
Each person has their own tastes, I've had Boge/Eibach, Bilstien and currently running Koni's with 3 dot spring. To me this is the best set up so far and won't be changing to anything else.
A Wrench
Suspension tweeks and drivers education will get you far more gains than sticking a K&N filter on it.
