transmission fuild leak
Hi!
I have a transmission filter gasket leak on my 86 928s so I'm replacing the gasket and filter, can anyone recommend a ATF type or brand?
Joe
1986 928s Weiss White Gold
Old 05-02-2014, 01:33 PM
928 Bro's Avatar
Do a search here or Rennlist.com. Alot of talk about Red line, Mobile 1, and Castro (synthetic type) but I have a 1980 and not sure what route I'm taking. Still have a few months to think about it.
Old 05-02-2014, 09:45 PM
MPDano's Avatar
I use Castrol Dex/Merc. More than likely not going to fix your leak. Known issue is the pump seal and only way to replace is to remove the Transaxle.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-02-2014, 10:15 PM
Petie3rd
Mrmerlin's Avatar
I suggest to use the Valvoline max life it comes in a red bottle,
works great in the power steering as well
Old 05-03-2014, 04:51 AM
Thanks for the recommendations! I see Castro comes up often, I'll check out the others, Is everyone draining the converter as well each time?
Joe
Old 05-03-2014, 12:11 PM
harborman's Avatar
You might as well drain the convertor, otherwise you still have a lot of old fluid in there.
Make sure you do not over tighten the pan gasket or it will leak.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-03-2014, 12:25 PM
MPDano's Avatar
Ditto, no need to recirc old dirty fluid with your new.
Also, while car is warm and running, get under the car (jack stands, of course) and see exactly where the leak is. On the 3 speeds, if it leaks right through the converter, then my original diagnosis will be correct.
Old 05-03-2014, 12:51 PM
Again great advice! thanks guys!
Joe
Old 05-03-2014, 05:12 PM
