-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   P Steering Changed Suddenly (http://forums.pelicanparts.com/showthread.php?t=820377)
SanDiego928 07-12-2014 12:31 PM
My steering became harder all of a sudden when entering the freeway after rounding an on ramp.
Checked hoses, belt, reservoir. Had my son turn steering back and forth and I saw no movement of fluid in reservoir. Fluid is about 1.5 inches from top of reservoir.
Is there any way of telling if it is the pump? Pump was rebuilt July 2013.
Thanks..... :)
Danglerb 07-12-2014 09:46 PM
Funky pumps usually make a noise. Flow should be obvious looking in the reservoir, I think anyway.
harborman 07-13-2014 06:23 AM
If fluid looks good and up, no leaks in system, belt is tight, it may be the pump. Rebuilt pump may be the problem.
SanDiego928 07-13-2014 09:02 PM
thanks guys. seems to be the pump but I would think it would make some kind of noise yet no noise at all.
riber.bentsen 07-14-2014 03:58 AM
Try changing the fluid first, it might cure it. Like an automatic transmission slipping because the oil looses viscosity over time.
harborman 07-14-2014 06:28 AM
I think my 928 uses trans fluid in the power steering. You might want to double check on that!
riber.bentsen 07-14-2014 11:26 AM
It does, all 928's do. Dexron III ATF.
SanDiego928 07-14-2014 06:05 PM
thanks, Yes auto trans fluid and 1 year old.
Mrmerlin 07-14-2014 08:30 PM
do you have a steel reservoir or the plastic version?
SanDiego928 07-14-2014 09:09 PM
Steel I believe. Top is metal, long threaded stem in the middle. Nice metal thumb screw looking thing, kind of neat. Always think I am gonna drop it somewhere in the bay unscrewing it.
Didnt even know there was a plastic one.
