Starting issue after engine is warm
I know I've seen this problem posted before, but can't find it. Porsche 928s euro starts fine when cold, but difficult to start after driving around for a bit. Any suggestions? Any help on where to start would be appreciated. Thanks
Old 06-24-2015, 01:24 PM
SharkHead
JhwShark's Avatar
You don't give much details.
A general known issue is a failing/failed Fuel Accumulator will cause a warm no-start condition.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 06-24-2015, 04:49 PM
Network Native
Danglerb's Avatar
Every model year had both US and Euro models, and lots change by model year.
Early CIS car nothing like L or LH.
Old 06-25-2015, 10:06 AM
S4hounddog's Avatar
Check the fuel pressure regulator. Pull the vacuum hose off and check for a gasoline smell, if yes then the diaphragm is shot.
Ray
1988 928 S4 5 speed "Loud Cars Save Lives"
1984 Carrera 3.2 coupe "The Mistress"
Old 06-25-2015, 02:04 PM
S4hounddog: thanks for the tip, I'll check it out. I was at work when I posted initial post and was in a hurry. The 928 in question is a 1980 Euro M28/11 engine with manual transmission. Engine always starts without any issues, but after driving a bit it does not want to start. I stopped for fuel and could not get it started without removing air cleaner filter and lightly pushing down on sensor plate. Appreciate any additional input on this matter.
Old 06-26-2015, 09:34 AM
SharkHead
JhwShark's Avatar
While, or before, you are sniffing for gas...
check in right rear wheel forward compartment where Accumulator is for gas as well. On the '80 I do not believe you have a return line from Accumulator, and you would observe gas smell from a failed Accumulator.
Old 06-26-2015, 11:12 AM
19psi's Avatar
On my '82, the problem was an inexpensive check valve on the fuel pump. Easy starts when cold but a pain in the ass even during the short amount of time to fill the tank at a gas station.
George in Indiana
928 Weissach #153
Cayenne S
Old 06-26-2015, 02:48 PM
Network Native
Danglerb's Avatar
80 Euro is CIS like the US 78/79. After the major failure smelling is done, you need a set of CIS fuel gauges and a shop manual to check pressures.
Old 06-28-2015, 07:37 AM
