Wiring Diagrams help
Going through wiring diagrams to track down an electrical problem. Coming across a feature I don't understand: there are, throughout the diagrams, square boxes with a number inside them (1-8) which are called "welding points". Can anyone explain what these represent?
SharkHead
I do not have an '88 but...
Can you upload a picture of the diagram and/or describe the function/item you have issue with? some joins are where wires are soldered/welded together along the run between point A to B to C...
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
Northern
This is 'thee' primer for learning how to interpret the 928 WD.
http://928-electrics.com/Docs1/Porsche%20928%20Electrics%200.85%20-%20WDP%20Only.pdf
87 928 S4 Indischrot - Siede Grau - Schwarz Leder - Unberührten Automatikgetriebe |
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Huge thanks!
