honerboys's Avatar
trans cooler
I have a radiator from a manual trans in the 84 auto now just while i'm working on it - so there is no trans cooler at all it it - so I was looking for an auto trans radiator when I ran across this on ebay
Behr Trans Cooler Performance Radiator 1986 Porsche 928S 84 86 | eBay
does anyone have this installed in their car - does it work as good as the in the radiator one - where does it mount - this would save me some $ as I wouldn't have to replace the whole radiator - thanks
84 928 S - SOLD
2012 Cayenne S
Old 09-04-2015, 08:56 AM
stepson's Avatar
I have both on the Stepson ('84 Euro AT). Radiator cooler and external cooler. I also run Dexron 6 which is synthetic.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-04-2015, 08:58 AM
honerboys's Avatar
hey stepson - did the car come with this cooler or did you add it - where is it mounted - do you suppose it would be enough to keep trans from overheating by itself or should I just bite the bullet and get an auto radiator - they are so expensive - I've also been looking at a Mercedes SL radiator - looks like similar trans ports - made for a V-8 - made by behr - and about $350 new - I would have to play with the mounts and trans lines though - thanks
84 928 S - SOLD
2012 Cayenne S
Old 09-04-2015, 02:23 PM
stepson's Avatar
Mine came with it. I always heard that heat kills transmissions. You would probably build a lot of heat in the mountains around Denver. I would want as much cooling as possible.
If you need a radiator with a cooler, I have a couple extra. I can send you pics and you can pick which one you want. Probably about $225 delivered.
Old 09-04-2015, 08:52 PM
stepson's Avatar
Forgot to answer the mounting question. It's mounted in front of the condensor coils down in front on the big cross piece behind the grill.
Old 09-04-2015, 08:54 PM
honerboys's Avatar
stepson - sent you a PM - thanks
84 928 S - SOLD
2012 Cayenne S
Old 09-17-2015, 08:46 AM
