AC fan relay
I have a 1980 and my radiator cooling fan properly kicks on when the temp switch triggers it. However, the fan does not kick on when I turn on my AC.
Any thoughts on typical fix?
Old 09-14-2015, 05:04 AM
kuehl's Avatar
Reading this thread AC Compressor Question
suggests the aux condenser fan motor would be turned on by AC when the temperature switch on the drier makes contact. Frankly I don't know off the top of my ed what temperature that happens at. You could test the sensor though (read the thread).
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 09-14-2015, 12:52 PM
Thanks. corroded connections to temp switch, fixed!
Old 09-27-2015, 05:54 AM
kuehl's Avatar
ahhhh, the simple things in life!
Kuehl
Old 09-27-2015, 07:33 AM
