-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   '79 rear CV boot and grease replacement (http://forums.pelicanparts.com/showthread.php?t=909724)
Rupesy 04-10-2016 05:51 PM
Just a few pics. Not a difficult job, just one of the messiest you will ever perform on this car! One of the most disappointing parts of the kit is that the clamp provided in the kit does not clamp down tight enough. I had to shim the kit 5 years ago and I had to shim these. Other than making sure you note the orientation of the components, not a bad job. Hopefully wont have to repeat this for another 5!
Typical torn boot. All four in the rear were torn. I had replaced the passenger side boots a almost exactly 5 years ago and they really didn't lats as long as I would have liked.
http://forums.pelicanparts.com/uploa...1460334027.jpg
http://forums.pelicanparts.com/uploa...1460335699.jpg
Time to dig in!
http://forums.pelicanparts.com/uploa...1460334323.jpg
http://forums.pelicanparts.com/uploa...1460334424.jpg
http://forums.pelicanparts.com/uploa...1460334514.jpg
Ground zero - some times it seems that there are just not enough rags in the word for this job!
http://forums.pelicanparts.com/uploa...1460334790.jpg
All clean
http://forums.pelicanparts.com/uploa...1460335081.jpg
Noted some wear
http://forums.pelicanparts.com/uploa...1460335231.jpg
Ready for packing
http://forums.pelicanparts.com/uploa...1460335284.jpg
http://forums.pelicanparts.com/uploa...1460335398.jpg
Rupesy 04-10-2016 05:52 PM
Packed and read for assembly
http://forums.pelicanparts.com/uploa...1460335458.jpg
Clamping the boot - some shims I had to use, a wire tie and the old clamp seem to be just enough to get it nice and tight. I know, not very professional but worked!
http://forums.pelicanparts.com/uploa...1460335650.jpg
Ready for re-install
http://forums.pelicanparts.com/uploa...1460335752.jpg
Installed
http://forums.pelicanparts.com/uploa...1460335783.jpg
http://forums.pelicanparts.com/uploa...1460335801.jpg
MPDano 04-12-2016 05:13 AM
Been there, done that, hated every second of cleaning and rebuilding mine. The boots are what gave me the most headaches.
Fischer_76_911S 04-12-2016 07:19 PM
Thank you for posting as I'll have to do mine at some point. Maybe I'll just send you mine, a box of rags, and $20! ��
