luthir2's Avatar
Send a message via MSN to luthir2 Send a message via Skype™ to luthir2
Engine Detailing
Greetings,
Currently working on my 80 S Row. Upgrading Transmission to an 89 5 spd with lsd. Will be doing timing belt, hoses and tune up.
While I am in there I want to clean everything up. What is the best Product for painting the intake tubes/manifold?
I remember reading that normal paint wot work do to the material. am I wrong? Thoughts or Idea's?
Teaks as always!
1980 928 S Euro
1987 928 S4
1986 944 N/A
2001 Boxster S
2000 996 Cabrio
Old 12-05-2016, 11:56 PM
Forget any paint, nothing beats powder coating..
Old 12-06-2016, 05:54 AM
Pete R's Avatar
I'm not sure what your original tranny is but when I upgraded my 79 tranny I also needed to change the torque tube, shift linkage and tranny cradle. The dimensions are about 3/4 of an inch different for mounting.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
luthir2's Avatar
Thanks Mike -> will look into local powder coating.
Pete R -> Thank you for the warning! I have the TT, cradle and all the suspension of the 89. am hoping the dual clutch will not be an issue.
I did not get the s4 calipers but have heard that the S Row calipers are almost as good. Guess I will find out .
Thanks!
1980 928 S Euro
1987 928 S4
1986 944 N/A
2001 Boxster S
2000 996 Cabrio
Old 12-06-2016, 11:10 AM
Pete R's Avatar
Thanks!
I am using a dual clutch with it as well. No issues. What sucks is you have to drop the clutch to unbolt the TT. You may want to refresh the TO bearing and rubber in the release lever. (your call) The S4 calipers look better, that's about it unless you're on the track. Street braking will be fine. The only thing larger brakes do is allow better heat dispersion for repeated stops.
Neon SRT4 track car
Old 12-06-2016, 12:13 PM
