No dash lights on S4
I believe the rheostat on the left under side of dash pod is for the dimmer. When I went to check that this morning one of my leads I was disconnected, and I found out that that was because the connector to the rheostat was broken. I jumpers the two leads like below and still not dash lights. I have 11.64 volts at the jumper.
That suggests to me that I am getting power there and it is likely bad bulbs?
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 09-16-2017, 08:45 AM
honerboys's Avatar
did dash ever light since you've had it ? - if it did it would be odd for all bulbs to go at same time - but they are all probably 33 years old
84 928 S - SOLD
2012 Cayenne S
Old 09-16-2017, 09:26 AM
Good morning, thanks for the note back.
No dashlights since I've had it, but agree odd they would all be out. That trigger an idea. Sat in OR for about 7 years so dealing with some electrical corrosion issues. Have not cleaned the steering column ground yet, since I can't find it.
Edit - looks like you have to pull the dash pod off to gain access to them.
911 w/ 3.2
Old 09-16-2017, 09:55 AM
JK McDonald's Avatar
Dwayne's Garage -
Hey TDSkip - To remove the Instrument Pod for a repair, Dwayne has some of the best step by step instructions around. You will want to select the "Pod Removal & Instrument Cluster Repair I" and/or the "Instrument Cluster Repair II". This will cover a lot more ground than you will need but it's nice to have on hand.
I've used "Dwayne's Garage" information for so many projects I can't count them all. Thanks again Dwayne-
Dwayne's Garage
Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 09-16-2017, 10:42 AM
Thanks Michael, will check that out.
911 w/ 3.2
Old 09-16-2017, 11:23 AM
