Alternator cable routing?
I got this car in pieces and I’m going back together with it. I obviously know what connects to the alternator. Where does the clip circled in red bolt to. Then it obviously routs under the intake. Does it get secured under the intake anywhere. Then where does it get routed, secured and connected from there. Thanks.
In the Fires of Hell.....
The white connector goes to the main wiring harness at the top of the firewall, where that connector's mate should be. Up near/above the brake booster.
The two connections on the left go to the starter, red to the solenoid, the black to the main post on the solenoid. Should be the hot side of the solenoid. The clip, I'm not certain, but I am thinking that it goes somewhere near the bell housing or up on the firewall. Take a better picture of it - see if that helps. Below is showing the routing of the harness across that metal holder using Omega clips, just where and above the red rag. The white connector can be seen above the brake booster. Good luck, Keith ![]()
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost Last edited by kdjones2000; 10-13-2025 at 04:28 PM.. |
