Turbo Blankets
Hi All,
Has anyone used a turbo blanket? PTP Turbo Blankets has a product that "seems" great but I am wondering if any of you have had any experiences with these? PTP Turbo Blankets Seems like if you combined one of those with a coated header/crossover-pipe/ down pipe you could really decrease engine bay temps? Thoughts? TIA
89' 951 Turbo S Race Car - SP-3, PT-B 87' 944 Diamond Blue Metallic - DD "Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley |
I have bought one myself, haven't tried it yet though as I am currently rebuilding my engine. Am gonna put wrapping on the manifolds and x-over also. reducing underhood temps is a good thing. Also it gives the added effect of hotter exhaust gas, which promotes spoolup/reduces lag.
_____________________________________________ Paul E. Johannessen from Bergen in Norway - 1972 Porsche 911, rebuilt to '76 Carrera 3.0 spec - 1986 Porsche 944 Turbo |
I wrapped a portion of my exhaust... the point at which it passes close to oil pan gasket. I cooked the crap out of my last gasket, although it was probably time to change it anyway. So I just wanted to keep a little of the heat away from it.
86 951 blk |
Jaxturbo,
I took my oil pan off this past week. The gasket looked new @ 109K mi. Do you have all the heat shields installed? Pax side under the headers and drivers side under the turbo oil line?
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
anyone install a turbo blanket on 951 ? Can i get it around the hot side by removing the TB and hard pipes ?
I have had a blanket on for 3+ years. I believe it was a PTP t3/t4 model. Need to remove intake to get access to install. I also wrapped my crossover pipe at the same time. Engine bay still gets incredibly hot. Not sure the blanket made any noticeable difference in underhood temps.
Yup, you pretty much have to take off the intake-manifold to get to the turbine. You're 80% there once you've got the charge-pipe off. Leave the throttle-body and fuel-rail attached to intake-manifold. Flip it over towards the passenger side, tie to cruise-control bracket and you've got full access to turbo.
