-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Remove ABS Pump, Bleed Necessary? (http://forums.pelicanparts.com/showthread.php?t=1034398)
RyanH. 07-10-2019 06:52 PM
I am cleaning up a bunch of surface rust in the front trunk under and around the battery. It extends below the ABS pump. If I undo the hard lines, do I need to re-bleed the brakes?
Kein_Ersatz 07-11-2019 06:32 AM
Yes, very much so.
RyanH. 07-11-2019 09:12 AM
That's what I thought. Due to the location, I'm assuming that I might as well just do a complete fluid change to ensure it's bled properly?
