-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Clutch slave bleed possible failure? (http://forums.pelicanparts.com/showthread.php?t=1051044)
wesleyc 01-27-2020 02:27 PM
I bled my slave today and had trouble getting fluid to push through. I had the motive pressure bleeder to 18lbs. Still nothing. I then pumped the clutch peddle a half stroke with my hand and heard a pop and it started bleeding. Now I can drive it but the peddle just returns to about half travel ? Question is. Did I mess up my master cylinder or something else? The fluid was very dark in the 993. Thanks
964TargaC2 01-27-2020 04:22 PM
Make sure reservoir is completely full and try bleeding some more, probably still have air in line.
wesleyc 01-27-2020 08:03 PM
Thanks for responding. The reservoir is full. I’ll give it another bleed though.
Nine9six 02-21-2020 01:01 PM
I agree... you still have air in your clutch slave line. Remove the air and you will have a full stroke pedal.
Kein_Ersatz 02-22-2020 05:17 AM
Yes, bleed again, and keep the reservoir full. Do not push your luck with the fluid level. There is a separator wall in the reservoir between the front and back of the tank and it is much easier to get air in the clutch line (back of the tank) then the brake line (front of the tank). Take smaller refill steps and refill much more often then you would for a brake bleed/flush.
wesleyc 02-25-2020 06:15 AM
Yes. I had air in the line. Never had so much trouble bleeding. Thought I’d broke something. Thanks guys.
964TargaC2 02-25-2020 09:50 AM
I have speed bleeders on my calipers and on the slave cylinder. I also use the vacuum bleeder from Harbor Freight. No mess no problems especially with the clutch, turn the bleed valve, hook up vac bleeder and push pedal a few times and close valve...done, Vac bleeder catches all that comes out
Probably works without speed bleeders but the Motive seems to be the gold standard here,,
wesleyc 02-26-2020 08:45 AM
I was using a motive pressure bleeder. I guess I just stopped to soon.
Kein_Ersatz 03-04-2020 07:49 AM
Glad to read you stuck with it and got it sorted out :cheers:
Frank Hanrahan 03-04-2020 09:08 AM
Speed Bleeders
Where did you get the speed bleeders? How do they work? Are they a pressure relief valve that only open when when they are unscrewed and the system is pressurized? Thanks
964TargaC2 03-04-2020 04:20 PM
Got the speed bleeders on ebAY and you are correct about their function
About clutch pedal you may want to try the MPL slave cylinder and the Stainless braided slave hose (The latter available from FVD)
Frank Hanrahan 03-04-2020 10:14 PM
The stainless brake hose is a great idea. We use them on brakes, why not. Is the MPL slave a direct bolt in? Does it have enough travel? Have you run one on your car? Thanks.
964TargaC2 03-05-2020 08:51 AM
MPL is a direct bolt on but you need to use the plunger and boot from your original slave
I have one (for a few years now) and made things lighter. I also replaced the slave line at the same time so I cant attribute everything to the MPL as my old line was a it on the way out
Frank Hanrahan 03-05-2020 09:40 AM
Awesome, thanks for the great information. I am looking forward to getting this project started.
wesleyc 03-06-2020 11:47 AM
Thanks. I felt quite silly for thinking it was something besides my impatience.
wesleyc 03-06-2020 11:52 AM
I’d never heard of the MLP slave. Sounds like a great product. Thanks for enlightenment.
Kein_Ersatz 03-07-2020 05:07 AM
Rennlist is the most active 993 forum I follow, lots of clutch mods detailed there, including the MLP details.
Frank Hanrahan 03-07-2020 06:24 PM
Thanks for the tip. I will spend more time there, somehow I got locked in to Pelican.
wesleyc 03-08-2020 12:03 PM
Do they sell these MLP slaves in the US. ?
964TargaC2 03-08-2020 01:29 PM
Years back they ran them on ebay and prices were all over the board, I had nothing else to do and watched and waited, got mine for about $70 Us plus ship[ping
I dont think they sell on ebay any more here is their web site
https://www.mpl-tuningparts.de/english/porsche.html
