-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   1996 993 turbo locking issue (http://forums.pelicanparts.com/showthread.php?t=1057723)
smizrahi9 04-12-2020 10:57 AM
My car is a 1996 TT. After taking it for service, the car has not been able to lock with the key fob. I hear that it tries and then a beep sounds as if something is still open. I have checked hood, trunk, doors, etc. all seems ok. from inside if I press the lock button in the console, all works fine.
I don't know how to troubleshoot it. I read the manual an it states that when someone opens is with a key, it may create a problem. I just don't know how to reset it.
I follow the instructions that if I press the key fob 6 times the car locks and it does but once I unlock it, it goes back to not locking.
HELP!!!
p911dad 04-15-2020 03:20 PM
A common issue is the battery going dead in the fob. I didn't see that you changed the battery. Maybe that will help. I believe Pelican has a article in the "how to" articles.
Fever 04-20-2020 05:25 AM
Probably batt on beeper, or you might have an issue with the inmobilizer.
Rigo.
