964 rear deck lid on 911?
Will a 964 rear deck lid fit on a ‘87 Carrera without any modification?
richard '87 Carrera 3.6L '92 968 race car ("Amy") |
Driver
No. While the exterior dimensions of the lids are the same, the hinges on a G-body are "narrower" (mounted closer together) than those on a 964. They're about 34" apart on the 964, and about 31" apart on my 930.
Plus you'd also have to figure out the wiring for the automatic tail on thr 964, and the "brain" that controls it.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Thanks Noah.
There's an old thread on this topic and one member even made (and still makes as best I can tell) modified hinges. I am now leaning towards a duck tail or simply keeping the turbo whale tail. Thanks again. Richard
I am pretty sure the hinges changed to accommodate the motorized wing of the 964. I don't believe the mounting points did so I believe you can use the 964 hinges with the lid on an early car possibly with some spacers. The earlier G body lid was used on the 964 turbo and RSA using adapters to make them work with the 964 hinges. I will see if I can locate my G body hinge i have and see if it mounts up to my 964.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Thanks very much for all responses.
Frankly, at this point I'm starting to lean towards the "duck tail" for an RS/outlaw look. What do you guys think?
Driver
Ducks look great. Maybe not as aero beneficial as the tea tray, but a Duck on a wide body is sexy as hell.
