-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   92 964 tip:ABS light, speedo out, tip manual out, spoiler light (http://forums.pelicanparts.com/showthread.php?t=1104021)
911Obbie 10-09-2021 09:41 AM
So - have owned this 92 targa tip since 2000. Rebuilt the engine 6 yrs ago.
This happened 3 weeks ago:
ABS light came on
Speedometer quit working
Tip on the manual side switches back to automatic after 2 minutes, and
Spoiler only works manually.
I also have the Durametric software for this car.
TIP ECU had not faults.
Motronic ECU 1 minor fault (it has never like my chip upgrade since 2003).
Most of the faults were AC/heater flaps issues.
Jumped on the forums here and Rennlist.
Cleaned front left sensor and replaced ABS relay with hew one from our host.
Everything above still the same.
I know the ABS unit has relays that may be suspect.
The car runs very powerfully since the rebuild, but this is annoying.
Any thoughts on what do to do next?
Thanks for any help!
ian c2 10-09-2021 02:44 PM
Abs supplies speedo , speedo supplies spoiler .
So concentrate on abs system .
Start with sensors , and power .
911Obbie 10-09-2021 04:25 PM
Thanks. Good summary of much of what I've been reading.
Will advise of progress and solutions for benefit of the forum.
group911@aol.co 10-10-2021 07:18 AM
Correct. If I remember right, the left front sensor is where it's read from.
911Obbie 10-11-2021 12:27 PM
Thanks.
Starting the process to work backwards from ABS sensors and connectors. Likely have to have codes checked re relays and FCU if sensor signals and signal paths are good.
power_up 10-14-2021 05:48 AM
ABS light came on
I have the similar problem occasionally. ABS light up and buzzer sound, Speedo meter quit working. Finding what to look up first. Hope you have clue.
911Obbie 10-20-2021 06:43 PM
I was very methodical wth the engine rebuild. Same approach here.
Was hoping the ABS relay change out would be the simple fix.
Will test ABS signal paths first.
Then power.
Then get codes read ie FCU and ABS unit relays.
If all is good then I've got to look at speedo.
Will keep all updated.
bazar01 10-20-2021 07:25 PM
Then power.
- Speedometer pin4 goes to R24 pin5 (FCU for control unit)
- R24 pin6 (input signal) goes to Wiring Diagram grid C35
- Grid C35 refers to ABS control unit pin17. (FRONT LEFT)
power_up 11-03-2021 12:00 AM
Updated my situation: My problem solved by replacing the R34 relay.
911Obbie 11-16-2021 06:21 AM
UPdate-
No signal from the left front sensor with a DVM.
Then did a brake test - 60 MPH, hits brakes hard..... front left wheel locked up.
Will procedd from here.
Thx for inout.
group911@aol.co 11-16-2021 06:27 AM
That sensor is easy to pull and inspect. It could be as simple as a bunch of metal fragments attached since it's magnetic.
Originally Posted by 911Obbie (Post 11519736)
UPdate-
Thx for inout.
911Obbie 11-16-2021 06:31 AM
I pulled, cleaned and reinstalled the sensor few weeks ago. It was pretty BAD. I didn't check the output at that time. Have ordered one from our host.
group911@aol.co 11-16-2021 06:35 AM
I think you can also swap left to right to quickly assess the issue
911Obbie 11-16-2021 03:42 PM
Thanks Bob.
Will keep working my way up the signal chain.
Do you know if this left front sensor feeds the entire signal path - ABS, frequency counter, speedo, tip ECU and spoiler? and, does the FCU have a code if in fact it's the culprit?
What's odd when I had it out was the Tip worked for 2 minutes then stopped. Speedo did not, spoiler did not and ABS remained lit the whole time. 120 second each on/off . ??
group911@aol.co 11-16-2021 05:59 PM
I don't know if it feeds all that but I'll bet Ian knows.
ian c2 11-20-2021 09:01 AM
It’s easy enough to check all 4 wheel sensors with a meter .
Unplug and insert test leads , and read ohms .
Should be around 1k , then spin hub slowly to see the reading move .
Another way is with a continuity beeper , should beep when plugged in but go on/off when hub rotated slowly .
Bear in mind pad sensor is simply open/closed so make sure you are connected into the right plug !!!
http://forums.pelicanparts.com/uploa...1637427564.jpg
I will clear space , and pm you my email as will be easier .
ian c2 11-20-2021 09:07 AM
Originally Posted by 911Obbie (Post 11520304)
Thanks Bob.
Wheel sensor goes to abs , abs goes to converter then speedo , speedo goes to spoiler .
When you say tip worked then stopped , you mean worked in manual then stopped ?
Did it fall into 3rd gear ? (Limp home mode)
Simple things first , is your battery good and fully charged ?
It’s pretty much a must for troubleshooting on any “modern” car …
Did you do a hard reset by disconnecting battery for 20mins +
911Obbie 11-20-2021 05:47 PM
Pic looks familiar with the leads in the ABS connector..... nothing. Waiting for the new one from
our host.
Re Tip not working: I can shift through 4 gears Tip mode, then after 2 minutes, the Tip gear indicator light on speedo goes out and drops to 4th. Not limp home mode but fully automatic. And runs great in that mode. First time i thought it was limp home mode (wasn't), pulled over. turned off, waited couple minutes, started back up and went through all 4 in Tip mode then back to only auto mode after couple minutes. Quite puzzling.
New battery last year. Holds strong charge ( I keep a bat/alt monitor that plugs in to cig lighter for occasional check . Replaced alternator 2 years ago.).
I have a battery disconnect because I sometimes don't drive for a couple months (but garage kept and does not see rain; it's also in most of the winter). So, yes it gets a hard reset regularly.
Appreciate any thoughts and help as I start working up the signal chain.
ian c2 11-20-2021 06:49 PM
If you definately have a sensor that tested bad , let’s wait to replace that before we work up the signal chain .
The front 2 sensors are the same , should you wish to swap whilst waiting for a replacement .
Another quick check while you have a repeatable fault , if you can please try to pull over and starting in neutral after a tip fault .
The good news is , you have a repeatable fault !!
Much easier to troubleshoot than an intermittent fault …
Next step would probobly be the speedo converter , as that takes a wheel speed sensor and converts to speedo signal . Speedo then controls spoiler through spoiler control unit .
If the converter is bad you lose speedo , and everything it controls .
You should find the speed signal converter in the front fuse box iirc
group911@aol.co 11-21-2021 10:18 AM
Ian
What does the neutral start tell you?
ian c2 11-21-2021 11:08 AM
Originally Posted by group911@aol.co (Post 11525285)
Ian
I Just wanted a memory refresh bob .
The car does a system check when first started which takes some time , and this is why problems show up when you’re driving down the road .
Iirc , starting the car in neutral means the system check does not start .
I think this was more for tiptronic faults than abs faults though , and might even be for getting it out of 3rd gear limp mode ?
Tip faults are much harder to fix as many inputs used from engine etc .
This is not happening in this situation , and I honestly think this thread will die once the proven bad wheel sensor is replaced ….
O/T ; Any news on that steering rack you was going to look at for me ?
911Obbie 11-21-2021 08:51 PM
THx Ian. I'll do the neutral test. What are thoughts about what that might show?
I've thought that maybe it is the FCU if everything in the signal chain is thumbs up after the new sensor is installed. Do you know if a code would reveal an FCU failure( or for that matter any of the ABS relays? ).
911Obbie 11-28-2021 03:08 PM
New sensor 964 606 403 02 came Friday.
Will put on this week.
Had the car out for drive and tried the neutral start.
Tip won't let you start except in P.
911Obbie 01-27-2022 06:20 PM
Ok. Been a while but will have an update in2 weeks.
PROGRESS!
911Obbie 02-05-2022 03:03 PM
So - here's where we're at.
I replaced the left front wheel sensor. Got good output but appeared to make no difference in the signal chain. Still had ABS lights and buzzer.
Then reseated every ABS relay- no difference.
So I decided to just replace the R34 ABS relay. 928 615 124 03.
Call it dumb luck, but ABS warning light and buzzer stopped coming on (nor coming on after warm up).
Still no speedo, cruise control, spoiler, and the tiptronic was doing the normal fault switch to auto after 3-4 minutes (consistently). So after reading here more, and Rennlist and talking with 30 yr experienced porsche mechanic, he suggested simply change out the R52 FCU relay which converts ABS signal into signal that drives speedo, spoiler, cruise and tip.
Found a new one 964 618 220 51 for $245 and decided to bite this bullet.
Now I have speedo and spoiler back. Tip still consistently in this fault mode, but for a longer time, so I'm suspect its not simply FCU output issue. And no cruise control.
More digging, reading and talking. Of suspect was either the tip control module, tip shift switch or combo of both. There appeared to be a higher likely hood of the TCM fault than the tip switch. Shopped around for a used TCM, got it in, and now I have the tip the working normally again. I will keep eye in the tip shift switch. Per my mechanic friend they (and PDK) shift switches are susceptible to fault with age).
On to the cruise control. Cruise is fused at #19. So are the brake lights. I have no brake lights and no cruise. I thought cruise would be resolved with the FCU replacement. Fuse was blown, replaced it and immediately blew again. Twice. Put 12v on the brake switch and had brake lights SO brake switch and wiring to the lights is ok but somewhere between fuse panel and brake switch I suspect there is short. Chaffing? Critters? I am going to start a separate thread for that issue. So if I find/fix the short and still have no cruise, that's a whole thread as well.
So this little adventure has brought a new wheel sensor, #34 ABS relay, #52 FCU relay and used TCM. Brakes light and cruise control next.
