Oil lines
This is probably the wrong site but I’ll try anyway. Has anyone run a number 16 AN line and a number 12 AN lined up through the heater duct in the right longitudinal of a 914 .do both of them fit ? I’m trying to reach dry, sump tank, thermostat, and cooler in the front trunk . Thanks for any info slammin out
I'm reasonably sure that could work but my 914/6 external cooler experience is limited was under the impression the lines are run externally down driver side ..
With a front mounted tank your option may be best I suggest taking your query to the 914world forum where more specific info may be found ...Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
