-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   964 engine noise (http://forums.pelicanparts.com/showthread.php?t=115698)
tedx 06-20-2003 10:28 AM
964 engine noise
When I drive my 92 cab 4 with the top down I hear a highpitch jingling/clinking/churping noise. It's most noticable between 2k and 3k rpms and is dependent on how hard I'm accelerating. Any ideas what this might be?
TIA
Ted
Rick Lee 06-20-2003 02:07 PM
Easy fix is to not let your engine get below 3k rpms. I cruise ta 4k and usually shift at redline.
Blu Bird 07-02-2003 07:05 PM
Check your heat shields. One may be loose and only reach another piece of metal to make the noise after reaching the RPM point. Is it at those RPMs in every gear or only when starting from stop using 1st or 2nd gear?
