jfawsitt's Avatar
WTB Porsche 993 Coupe Driver's Side (Left) Main Door Seal
I'm looking for an original equipment 993 driver's side main body door seal, NOS or used in very good condition, part number 964.531.950.00. Porsche and the aftermarket no longer make this in the original design.
Thanks,
JF
Old 02-10-2024, 08:38 AM
Are the new ones bad, really bad or what?
Do they look different, don't fit well or both?
I've always used factory seals as aftermarket seals never fit well.
Sad to see the factory parts are not original.
I have the same seal needing replacement.
Jim
Old 03-01-2024, 10:27 AM
I recently installed the door seal on the driver side with an aftermarket part on my 964 and I’m not ecstatic with the finished result. Specifically it seems the new seal is too thick and closing the door requires quite a bit more effort than before. I’m going to give it another couple of months to see if it compresses with time but if it doesn’t I’m going to have to get an OE part and hopefully get better results. I wonder if the 993 seal has similar issues?
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 03-01-2024, 06:08 PM
jfawsitt's Avatar
Jim
Hi Jim,
The OEM seal that Porsche sells now is thicker and a different profile (ribbed as opposed to smooth). It's also one seal for both left and right sides, the original was specific to each side. The new seal is a compromise at best, doesn't look correct and makes it difficult to close the door without slamming it.
I looked under every rock on the internet for a new old stock one with no success, apparently, they go for $1k when they do pop up. I was fortunate enough to find a decent used one for $300.
This is one suggested solution from Rennlist:
"http://993servicerepair.blogspot.co...door-seal.html"
Good luck!
Old 03-02-2024, 05:59 AM
Originally Posted by jfawsitt View Post
Hi Jim,
Good luck!
Pretty much my observation after installing one a few weeks ago. What’s interesting is that the door is only difficult to close if the everything else is closed up, if the passenger door or windows are open the door closes with much less effort. It’s almost as if it’s not allowing the air to properly move.
CURRENT:
Old 03-02-2024, 06:37 AM
Thanks.
Nothing helps more than shared depression.
I knew they were expensive but had no knowledge of any change.
New seals will always fit tighter and the 993 was made to be air tight therefore the push back shutting the door.
Time to do door handle seals, speakers and this one door seal.
Jim
Old 03-08-2024, 11:43 AM
PCA 993 Registry Advocate
The current Porsche parts numbers do not work, they are too thick and based on an earlier 911 part. Another failure by Porsche Classic.
This part has worked for a number of 993 owners. I have not tried it yet.
https://www.pelicanparts.com/More_Info/91153109503.htm?pn=911-531-095-03-M253&bc=c&SVSVSI=0650
Old 03-09-2024, 08:31 PM
Cobalt's Avatar
Hard to say Porsche classic failed it is a compromise but we are fortunate enough to have classic parts. Many marques don't support cars over 10 years of age.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-12-2024, 07:04 AM
