OZ Wheels
Can anyone tell me if the following size rims and tire would fit a
1992 C2 964? They are beautiful but I would like to make sure the size and offset is correct before I commit.
Included with this set are hand painted center caps.
The brand new Yokohama AVS ES-100 ZR-rated tires have
the following specifications: Fronts are 225/40 ZR 18,
18 X 8.5 with 44mm offsets Rears are 265/35 ZR 18, 18 X 10
with 47mm offsets
Old 11-19-2003, 05:36 AM
The rears are the same as the wheels I had on my 90 C2 so they should fit. The fronts are normally 52mm so they may sit too far out beyond the fender line plus, they may be too wide.
Old 11-19-2003, 09:09 AM
Thanks for the info. I guess I will continue the hunt.
Old 11-19-2003, 09:18 AM
