Central Warning Light
After the recent purchase of my 91' C2 964 I noticed that the Cental Warning light indicator on the dash does not light when the vehicle is started. I did notice that the warning cancel button on the console is lit and if I reset it it will go out. The car seems to be running fine but I am concerned if there is a hidden problem that I missed. Any help would be great. Thanks in advance
Could be the P.O. removed a warning bulb from one of the dash gauges. I had to remove my air bag bulb because I inadvertently started my car with the crash sensor disconnected while doing some work on it. The warning light was a nuisance and I pulled it until I get a chance to have the dealer clear my fault code. So pull all your gauges and look for a burnt or missing bulb,or get the the fault codes checked at the dealer. Also check Rennlist 964 forum for the check engine light method to pull fault codes.
Thanks for the info I will check this out
| All times are GMT -8. The time now is 03:31 PM. |
