-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   964 and 993 Engine Questions (http://forums.pelicanparts.com/showthread.php?t=143993)
9magazine 01-14-2004 05:44 PM
Hey everyone,
Need some answers for the following questions, thanks!
964
Engine idle speed?
Type of spark plug and gap?
Timing?
Valve clearance measurement?
Air filter model number?
oil filter model number?
fuel filter model number?
993
Engine idle speed?
Timing?
Thanks,
Brian Minson
Publisher/Editor
9, The DIY Porsche Magazine
http://www.9magazine.com
Lorenfb 01-16-2004 08:26 AM
Sounds like you need to buy some Porsche manuals.
9magazine 01-16-2004 08:28 AM
I need more info on the 964s and 993s. I have all the FWS manuels for the other models.
Might just have to do that soon! :)
Brian Minson
Editor
Jim Richards 01-16-2004 09:20 AM
Brian, unless someone provides the info first, I'll try to get you the 993 info when I'm back at home this evening.
9magazine 01-16-2004 09:27 AM
Jim,
Please do so, thanks!
Brian @ 9 Magazine
expat 01-16-2004 10:06 AM
964
Engine idle speed?
880 + or - 40rpm
1000 +- 50rpm on Turbo 3.3
950 +- 50rpm on Turbo 3.6
Bosch FR 5 DTC 0.8 + or - 0.1 mm
Timing?
0deg + or - 3deg at 880rpm on Turbo models
intake opens 4deg. bf TDC, intake close 56 deg. bf BDC, exhaust opens 44 deg. bf BDC, exhaust closes 4 deg. bf TDC on M64/01 & M64/02
intake opens 3 deg. bf TDC, intake closes 37 deg. bf BDC, exhaust opens 27 deg. bf BDC, exhaust close 5 deg. bf TDC on M30/69
intake opens 2 deg. bf TDC, intake closes 54 deg bf BDC, exhaust opens 43 deg bf BDC, exhaust closes 3 deg. bf TDC on M64/50
intake 0.1mm (0.004in) exhaust same
More to come soon
Jim Richards 01-16-2004 07:27 PM
OK Brian, this is what I have -
993 N/A
Engine idle speed? 800 rpm +/- 40
Type of spark plug and gap? Bosch FR 6 LDC 0.7 +/- 0.1 mm
Bosch FR 5 DTC
Beru 14 FR-5 DTU
Timing? 1 mm valve lift, zero clearance:
Intake opens: 1° BTDC
Intake closes: 60° ABDC
Exhaust opens: 45° BBDC
Exhaust closes: 6° ATDC
Valve clearance measurement? n/a - Hydraulic lash adjustment
Air filter model number? 993.110.327.00
oil filter model number? 993.107.203.03 & 993.207.201.02
fuel filter model number? 928.110.253.04
993 Turbo
with A/C on: 880 rpm +/- 20
Beru 14 FR-6 LDU
Intake opens: 12° BTDC
Intake closes: 117° BTDC
Exhaust opens: 124° ATDC
Exhaust closes: 5° ATDC
Air filter model number? same?
oil filter model number? same?
fuel filter model number? same?
Bill Verburg 01-18-2004 04:16 PM
964 M64/01
IO 4&deg BTDC
IC 56&deg ABDC
EO 45&deg BBDC
EC 5&deg ATDC
993 M64/05
IO 1&deg BTDC
IC 60&deg ABDC
EO 45&deg BBDC
EC 5&deg ATDC
993 M64/21
IO 0&deg BTDC
IC 59&deg ABDC
EO 47&deg BBDC
EC 5&deg ATDC
993tt M64/60
IO 12&deg BTDC
IC 63&deg ABDC
EO 56&deg BBDC
EC 5&deg ATDC
964t 3.3t M30/69
IO 3&deg ATDC
IC 37&deg ABDC
EO 27&deg BBDC
EC 5&deg BTDC
964t 3.6t M64/50
IO 2&deg ATDC
IC 54&deg ABDC
EO 47&deg BBDC
EC 3&deg BTDC
