exhaust recos for 90 964
hi all,
have a1988 carrera w/ 90 964 transplant, just wonder all's opinion on exhaust upgrade w/ heat exchanger for greater sound and perhaps a gain of hp for track days. budget has to be considered. thanks
91 3.3T 98 M-3 4dr |
I have the GHL full exhaust system on my 964. It's a little on the loud side since I'm not running their dual cats. I get a little resonance (sp?) around 4K. However, I'm very satisfied with the product and their customer service is great. The price of the entire system (headers/exhaust) may be out of your price range if you're on a tight budget. I think I paid under $2K about a year ago.
John 1997 993 2012 991 |
Option 1
SSI w/ the muffler of your choice, homemade heat ducts Option 2 B&B, w/ Flowmaster type crossflow muff, oem 964 heat duct Option 3 Instant Gs headers Steve Timmins stuff Option4 993 headers/ w adaptersas installed by Rennsport Systems
Bill,
Could you elaborate on option 1 - SSI w/ DIY heater sysem? Thanks
Grady aka plain fan 66 912 - enjoying the good life 78 911 SC and 90 C2 turbo look cab - gone but not forgotten 01 996 TT - ![]() 09 Audi A4 Avant - daily driver |
To hook up heat all you need is to modify the 964 heat tube just after it drops below the tin work as pictured here ![]() just use ~2.5" hole saw to drill a hole in the side of the stock tube, size the hole so that the duct fits snuggly in the hole, run this duct to the left side ssi heat inlet. I used a silicon sleeve, from the stock 964 heat, to clamp in place on the ssi. The reducer at the bottom is a std. aluminum dryer vent piece which connects to some ss or galvanized 2.5" flex tube. The flex tube crosse to the other side where the final 180° bend is again made w/ more flexible duct, claped on w/ the silicoon sleeve. it was a while ago so take the posted sizes w/ a grain of salt. Worked great.
Oh, the SSI's also needed a spacer to push the muffler back a bit.
Thanks Bill, I was thinking that the SSIs would be too restrictive. What are you running now?
So B&B headers with DIY flowmaster type of muffler.
I've found that combination to work well. It's a bit on the rowdy side, but I can live with it easily.
Timmins/Mcneil kit has gotten some good reviews sound wise.
If anyone is interested I'll be posting the following for sale soon ... send me a PM/e-mail if you want more info/pics.
* new/never used B&B 964 headers - will need a dual-in muffler added to it to complete the system. Approx 22RWHP gain and 45-50lbs lighter and OEM system. * new/never used B&B 964 single-in/dual-out muffler for OEM headers/cat. Approx 10RWHP gain and 34lbs lighter than OEM muffler(s).
Project935 Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06 Gruppe B #101 What's next? |
Hi Bill,
thanks always for great infos, but i thought SSI does not have a header/ heater box system for 964 C2 3.6 engines. your option 2 is exactly what I was leaning towards. best regards, DH
Who have tried 993 headers on 964s ? Some say they are really more efficient
The only problem with them is that 2 pipes have to bo turned
What can you dream on when owning an RS ? ______________________________ http://www.ma964rs.com |
