964 Climate Control Troubleshooting
Last month (December - winter in NY), I purchased a 1991 Cab C-4. Unfortunately the Climate Control does not work properly. The symptoms are:
1) Constant heat from driver's side & middle vents. Far right passenger's side vent blows cool air. 2) Round thermostat dial (blue & red dots) does not work. 3) Slide Controls appear not to work. 4) Blower fan 0 to 4 does work properly. 5) Defrost button engages & blasts air through vents not to glass. 6) A/C button turns on (yellow light) but the condenser/compressor appears not to engage -- no change in RPM's, etc. I have Adrian Streather's 964 book & it appears that the two mixing chamber Servo valves under the front hood may be bad. Any other ideas? Thanks. This is my 1st post! Pete |
Hey Pete, congratulations on a beauty purchase. I cant offer any technical help personally but take a look at (www.porsche964.co.uk)
follow technical link, to electrics, and at the bottom is an excellent article on the heating and servo repair. Loads of photos! I doesnt look to bad to fix. similar problems were described. I hope it helps. Darren By the way just purchased'91c2 coupe in December in Canada. |
Do anyone know where to find above article about servo repair? It has been referred in many posts but looks like www site is no more working.
I may have heat servo trouble and would be nice to see how one has repaired them. |
The most common fault in the servos are weared-out potentiometer tracks and burnt whiskers. This is not possible to repair, you'll have to get a spare. I have seen very few, if any, other faults in these units.
I've got a newly updated Porsche HVAC page here, I doubt you'll need any more info than that. ;-) Here's a cached version of the 964 page mentioned above. Cheers, Tore |
| All times are GMT -8. The time now is 07:01 AM. |
