ecm911's Avatar
Brake rotor ?
I have a 93RSA with front turbo brakes (965). I use the same pads as a 993. Will a 993 rotor fit on this ?
I am trying to get a used 993 rotor to try. But thought someone may know.
Reason, $$$
I do about 20+ days of track per year and go thru a set of the 965 rotors each year. They crack!!!!! and 993 rotors are cheaper.
Also, does anyone know if solid rotors can be had for the 965 application. I figure I may get some more life out of these rather than the cross-driller. Since I never really have significant wear. Trade , i know would probably be more heat. But it may still end up with long rotor life?
thanks
78 SC Coupe
93 RSA (Gone)
Old 03-15-2005, 05:54 PM
Bill Verburg's Avatar
No the 993rotors won't work
I think I remember that someone was using 928 S4 1986-1991 rotors
Bill Verburg
Old 03-15-2005, 06:25 PM
993 rotors crack as well. Bill is right, they will not fit. I think they are offset too far..
Chris
Old 03-16-2005, 05:57 PM
