Moki's Avatar
Porsche Crest Fuel Gauge
Does anyone have a wiring diagram for fuel level indicator circuit? I am trying to diagnose my fuel gauge problem. I was driving my 91 C2 last week and everything was fine until I stopped for some coffee. I returned to my car and the fuel light was on and the fuel level was registered at zero and there was at least 3/4 of a tank of gas. This was further confirmed two blocks later, the fuel level indicator returned to 3/4 but the fuel light stayed on. Not much later, the level indicator went back down to zero and never returned.
Is there any way to tell, if the fuel level sensor in tank has gone south, the fuel gauge is shorted out, or other electrical probelms within the circuit?
Any help will be appreciated.
2003 R1100S BCP w/Ohlins, PVMs, Laser II, Motoyoyo clamps & 10 mm telelever mod, 1290 R, S4RS, RC30, FZR 400, KTM DUKE 1290R, Fat Boy
Old 04-01-2005, 04:46 PM
AFJuvat's Avatar
Most likely, your fule level sender has gone south. Essentially, there is a float in the sender that runs on 2 wires The variable resistance as the float moves alond these wires is what causes the gauge to fluctuate. at a preset point, the float will trigger the low fuel light. Over time, the wires get corroded and things tend to stick.
You can double check the electrical connections on teh back of your fuel gauge, but your problem most likely resides in the sender.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-02-2005, 12:03 AM
Moki's Avatar
Porsche Crest
Thank you for the response. I will start there.
Old 04-02-2005, 10:14 AM
rboylan's Avatar
Check out this link. The problem may be tied to this:
http://p-car.com/diy/clockrepair/
Good luck.
1969 911E Albert Blue 1970 911E Iris Blue
1970 911T Signal Orange 1972 911T Gold Metallic
1981 930 Arctic Blue 1981 930 BB Auto(on ship)
1987 930 Cassis Red Met 1996 993TT Black
2007 997TT Cobalt 2017 991 Turbo Cab
Old 04-02-2005, 05:49 PM
