If the stars are "anti-squeal", they must not be working. Are they necessary?
here's a pic http://forums.pelicanparts.com/uploa...1255388266.jpg the spyders fit in the caliper piston holes http://forums.pelicanparts.com/uploa...1255388314.jpg |
I will try the pads without them. Thanks! do most people find that they help with squeaky brakes? The factory must have thought so.
do you have experience with filing pad edges to reduce squeal? |
I don't use anything more than the pad. Just slide them in and remember that the first time you use the brakes it may take a bit to re-extend the pistons. Just pump the pedal once or twice before driving.
| All times are GMT -8. The time now is 08:09 AM. |
