Rocker Panel Welting Sinking...
'90-964-C4-Cabriolet
The welting (Mostly on the passenger side) between the rocker panel and the main body panel is gradually sinking into that space.
Is there a way to "retrieve" it and reposition it or should I just pull it out and affix new welting?
Must be some folks here who have had the same issue, I'm Sure!
Any help would be Greatly Appreciated!
Best Regards,
Tony
90-964-cab
Old 08-15-2015, 08:00 AM
964TargaC2's Avatar
It could be glued/siliconed in place but its relatively cheap for a Porsche part and face it, its 25 years old. Make sure you order new clips and pins to reinstall as they are brittle and break easily
Also make sure you undo the screw at the front and the nut at the rear
I think that maybe I'm dreaming..
Old 08-15-2015, 07:06 PM
Roger that, 964TargaC2...Thanks for the comeback!
Best Regards,
Tony
90-964-cab
Old 08-16-2015, 01:57 AM
