964eng / G50 will not separate
I can’t get the transmission to let go of the engine. All the bolt are out, the starter is off, the hydraulic clutch is off, I can get it back ¼ to ½ of an inch but that’s it. I’ve been wiggling, pulling, prybaring, what’s the trick??? Clutch is a not duel mass.:mad:
Did you take the clutch-fork out?
Without that, you cannot separate the gear-box. Sebastian |
Nope I just learned you need to do that. never had to with a 3.2 or SC eng. :D
| All times are GMT -8. The time now is 10:54 PM. |
