-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Mixing Synthetic & regular oil (http://forums.pelicanparts.com/showthread.php?t=294969)
btsave 07-23-2006 02:33 PM
Can mixing synthetic (Mobile 1 ) oil and regular oil cause any problems in a 964?
thanks
oliver88 07-23-2006 03:05 PM
Mixing is usually not an issue at all. Unless you are using a castor based oil i would not be concerned.
Paul Crowther 07-23-2006 05:03 PM
I've heard the same. Don't add synthetic to an engine that hasn't been running synthetic regularly, but you can certainly add regular oil to a synthetic-using engine.
Paul
aigel 07-23-2006 09:55 PM
Mixing is better than running out of oil, which is what would have happened otherwise, I assume. However, I'd change the oil sooner than later - not waiting for the next interval. For the next time, just keep a quart or two of the matching oil in the car. ;)
Cheers, George
kang 07-24-2006 08:39 AM
Yes, you can mix, but why do you want to?
rfuerst911sc 08-02-2006 09:58 AM
No issue.
