-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   993 MAF Sensor? (http://forums.pelicanparts.com/showthread.php?t=302355)
WydRyd 09-03-2006 06:25 PM
993 MAF Sensor?
Hey 993 guys, do any of you know whether the 993 uses the same MAF sensor as the 993TT?
Here's a pic of the 993TT unit:
http://forums.pelicanparts.com/uploa...1157333051.jpg
I ask because I'm researching what's required to convert my turbocharged Carrera (using OEM AFM) to a less restrictive 993TT MAF setup :confused:
kang 09-05-2006 08:27 AM
A quick search of our host's parts database only shows one MAF for 993's:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911L&section=FULint&page=2&bookma rk=18&part_number=993-606-123-01-M14
kang 09-05-2006 12:41 PM
On the other hand, I checked a different vendor, and they show two part numbers...
Carrera3.5L 09-05-2006 12:50 PM
Porsche PET lists separate MAF's for normally aspirated & turbo models...:)
Ralph
WydRyd 09-10-2006 02:20 AM
It's OK, I decided to buy a piggy-back MAP-ECU and go to a speed density setup to replace the AFM ;)
ChinSCoupe 09-15-2006 02:16 PM
Merv, which setup are you going to use?
Colin
