-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Spoiler Problem (http://forums.pelicanparts.com/showthread.php?t=315007)
Neufman 11-13-2006 07:21 PM
Spoiler Problem
993 (1996 c4 cab) witih automatic spoiler: the manual button works to raise and lower it, but suddenly it won't work automatically. So the moter works, but can find the sensor / sender part that has it raise and lower. Any help would be appreciated. Thanks for the assistance; my first post
Don Plumley 11-13-2006 08:33 PM
Welcome.
It sounds like the spoiler control module which is found under the dash. For more exhaustive resources, here's a link to a search I did on Rennlist .
Don
dependencies 12-16-2008 12:32 PM
What would likely have failed though,
if spoiler deploy automatically and parks at low speed,
but won't do anything off the manual control?:confused:
Is there for example more than one fuse where I might start looking
thanks
bobesser 12-18-2008 03:39 PM
I have all spoiler control parts from a conversion to a fixed spoiler. Make an offer if you need parts.
Bob
Don Plumley 12-18-2008 05:04 PM
What would have failed is either the spoiler control module or the speed frequency converter. Not a fuse, since the spoiler is working semi-auto: You can raise it, and then it senses the car is going zero, so it lowers it. This points to the spoiler control module.
dependencies 12-19-2008 01:00 PM
Don.....Correct:)
After a replacement module arrived
(which sadly proved to have wrong number of pins) a subsequent delivery solved the problem
thanks again for pointers as always
