Spoiler Problem
993 (1996 c4 cab) witih automatic spoiler: the manual button works to raise and lower it, but suddenly it won't work automatically. So the moter works, but can find the sensor / sender part that has it raise and lower. Any help would be appreciated. Thanks for the assistance; my first post
Old 11-13-2006, 07:21 PM
Don Plumley's Avatar
Welcome.
It sounds like the spoiler control module which is found under the dash. For more exhaustive resources, here's a link to a search I did on Rennlist .
Don
Don Plumley
M235i
Old 11-13-2006, 08:33 PM
What would likely have failed though,
if spoiler deploy automatically and parks at low speed,
but won't do anything off the manual control?
Is there for example more than one fuse where I might start looking
thanks
Nineteen Ninety One 964
Old 12-16-2008, 12:32 PM
I have all spoiler control parts from a conversion to a fixed spoiler. Make an offer if you need parts.
Bob
Old 12-18-2008, 03:39 PM
What would have failed is either the spoiler control module or the speed frequency converter. Not a fuse, since the spoiler is working semi-auto: You can raise it, and then it senses the car is going zero, so it lowers it. This points to the spoiler control module.
Don Plumley
M235i
Old 12-18-2008, 05:04 PM
Don.....Correct
After a replacement module arrived
(which sadly proved to have wrong number of pins) a subsequent delivery solved the problem
thanks again for pointers as always
Old 12-19-2008, 01:00 PM
