964 Spoiler (rear wall swap)
My 1990 car has a damaged/split rear wall, the previous owner has
attempted a repair thast hasn't worked out very well.
I know the part is available here.
and on the diag' it looks to be fixed at Four points
(Two top and bottom)
what needs to come off, is it do-able?
Cheers chaps
Nineteen Ninety One 964
Old 08-15-2007, 12:38 PM
kurquhart's Avatar
This is a 993 DIY, but it might help you out?
http://p-car.com/diy/spoilerwall/
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 08-15-2007, 04:05 PM
ebenke's Avatar
I did the entire swap in about ten minutes, and I didn't need to remove anyother parts parts. Mostly is snaps off and on. Take a look at it I think you will find you can do it the same way. I had to adjust the wing height a couple of times during removal/installation, but thats it.
It snaps into channels on the top and bottom
Good Luck!!
E Benke, Florida, USA
1993 964 C2
Old 08-15-2007, 05:42 PM
Don Plumley's Avatar
Yeah, you can slide it in from one side.
Don Plumley
M235i
Old 08-15-2007, 07:56 PM
Oh that sounds OK
From the basic drawing on here it could be easy or difficult
I'll order one up
Thanks again
Old 08-16-2007, 12:43 AM
