Mammalian
96740's Avatar
Air box up-grade. Opinions.
What are your experiences with a particular airbox up-grade?
Factory Motorsound, Fabspeed, Etc..
Any increase in HP? or just better sound?
2007 Cayman
Old 09-20-2007, 08:20 PM
Tom W's Avatar
HP increase? I really doubt it. The drilled cover does sound better (louder) at wide open throttle.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 09-20-2007, 10:49 PM
the drilled cover does sound GREAT!!!! i just did it..... it gives about 25 "EAR" wheel horsepower......DAMN does it sound good!!
Old 09-21-2007, 05:48 AM
Cobalt's Avatar
I have the fabspeed cup box and RMB sounds great but I doubt it helps with power. It might open up some mid range response but negligible at best. Did I mention it sounds great.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 09-21-2007, 12:27 PM
Newsboy's Avatar
Definitely a nice sound increase. You don't neeed to buy an aftermarket cover, just drill out the airbox yourself. I have approx. 20 1" holes in mine.
Old 09-22-2007, 04:19 AM
Mammalian
96740's Avatar
I'm going to try and find a stock airbox, or at least the cover. And drill the holes.
I've looked on eBay, but none right now. If anyone has one or see's one, give me a holler.
2007 Cayman
Old 09-22-2007, 06:42 AM
call dcAutomotive at 252-977-1430 and order it from them
Old 09-24-2007, 11:06 AM
Cobalt....what is an RMB? thanks
Old 09-24-2007, 11:07 AM
Cobalt's Avatar
Sorry "Rear Muffler Bypass" also known as G pipe.
Old 09-24-2007, 11:51 AM
is that the little "C" looking pipe? is it loud?
Old 09-24-2007, 11:57 AM
Cobalt's Avatar
Yes it is. It is louder than stock but sounds great. Has a nice growl and sounds like it should IMO. It does not resonate like some after market exhausts and is legal even at Lime Rock by a fair amount.
Old 09-24-2007, 12:00 PM
is it tough to install?
Old 09-24-2007, 12:13 PM
Cobalt's Avatar
Easy as they get unless the bolts are rusted solid maybe an hour. Once you have done one maybe 25 min. It also saves 25-30 pounds off the rear end.
Old 09-24-2007, 12:27 PM
i guess just loosen the bolts that hold the muffler on and replace it with the pipe? is the muffler on the passenger side?
Old 09-24-2007, 12:34 PM
Cobalt's Avatar
Passenger side. IIRC here are 2 bolts with spacer sleeves towards the back of the muffler that are removed. There is a clamp from the primary muffler with a sealing ring. Loosen this and remove the muffler. Then loosen the clamp and exhaust pipe from the muffler. Attach the exhaust pipe/tip to the G pipe and using the sealing ring from the primary muffler install and tighten. It takes a little playing with to get it adjusted properly. Be sure your about 1/2 inch away from the bumper all the way around.
I know it is a bit basic but once your under there it will become clear.
Old 09-24-2007, 12:51 PM
thanks!!
Old 09-24-2007, 01:05 PM
Mammalian
96740's Avatar
Drilled out the Air box today similar to these pics. Very nice sound boost. Not much more than that.
Thanks everyone for the advice and feedback.
2007 Cayman
Old 09-24-2007, 02:10 PM
bigchillcar's Avatar
i have the k&n air filter..does the same thing..more growl.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 09-24-2007, 09:37 PM
It has been documented that drilling the top cover of the airbox does increase the engine's output by 6-8HP in a 993 engine. Bruce Anderson reference. The stock opening where the air goes into the filter is a bit restrictive and the engine has more volumetric efficiency that is achieved by giving the intake more holes to suck air into the engine. The HP claims from K&N and others are mythical in the 964 and 3.2L engines which are restricted by the older barn-door air flow sensor intake after the air-filter intake. Those airbox holes only make more noise and probably has no increased in HP (unless chipped).
Old 09-25-2007, 07:31 AM
don't know of any horsepower gain from the k&n air fllter in my 964 (car is cyntex chipped), but the sound is very nice with it. if that's the only benefit i'm okay with it, and it likely is.
Old 09-25-2007, 10:57 AM
