964 upgrade for lights?
Are there any recommended upgrades for the lights on a 964? Do later model
litronics fit? |
I have H4 headlights in my 964 and I have upgraded to a H4 "Xenon" single filament replacement.
Kenhill,
Where can these bulbs be found? |
H4s aren't designed for high intensity discharge (technology litronic uses). I've compared with a friend and it looks like the PIAA colored bulbs are pretty nice (nicer than the xenon ones I have). They list a bunch of junk on their website about 55W headlights being the same as 110W or something of output, but it's a bunch of junk - notice they don't list the lumen output (which is sometimes lower for these colored halogen bulbs that have higher color temps).
I used to have H4 lamps with Hella 80/100w bulbs. Now those were bright. If you do use those, it's a good idea to wire a relay to the headlight switch if 964s run all the power through the switch like the water cooled Pcars did. |
Where can you get the proper h4's? I'm guessing that they are not the same as the early cars, right?
Have a look on eBay - they are becoming more common and the installation including relays and ballasts is not difficult. |
Try these guys....... I've bought a number of bulbs from them and they're great!
LINK: |
Get a pair of Sylvania Silverstar Ultra bulbs and you'll be all set. Huge improvement!
| All times are GMT -8. The time now is 05:45 PM. |
