Opinion on trans gearing
I am looking at a supposedly motorsport trans, it has the 8/32 ring and pinion and all steel syncros.
1st- 13/41 2nd- 16/36 3rd- 20/34 4th- 21/28 5th- 25/29 6th- 33/44 Any help appreciated since I dont know how to make a gear chart. What is a trans like this worth? Is it much better than the 98 G50/20 unit I already have? It seems 1st and 2nd will be VERY short. |
double check 5 & 6, there is something hinkey about them, especially 6
yes, it seems very short
Thanks Bill,
I will check 5&6 again. whats your opinion on the rest of the gearing? Is it usable on the street ? what speeds would 1st and 2nd achieve |
I searched the archives and found some pretty good info
http://forums.pelicanparts.com/showthread.php?t=276073&highlight=transmission+gearing&page=2 |
this is JMO, the /20 is too short in 1 and too long in 6 w/ revs and tires the same for all the box you are looking at 1>4 only is 39 62 82 100 my /30 is(I wouldn't go shorter than this) 46 72 95 119 a /32 is 46 72 95 116 a /20 is 38 71 103 129
They are asking $7000 and I was thinking of selling off my trans to help pay for the other unit but it seems like I am better of finding a unit with better ratios.
The trans that I am looking at, the gearing does not seem to,to bad but I dont want to be revving at 3500@75mph in 6th either. Thanks again for your help. |
The worst thing about the /20s is that sometime in '95 and then up they started using 1 & 2 integral w/ the main shaft, to change them you need to replace the mainshaft
While steel syncros are nice, they are awfull expensive, $7k is getting to the range where you can get a factory rebuilt /31, the /32 is much more expensive. A reasonable alternative is to redo the /20 3 > 6 maybe something like this, again same tires and revs as above for comparison 1 11:42 stock ~38mph 2 21:43 stock ~71mph 3 20:31 ~93mph 4 24:30 ~116mph 5 32:33 ~140mph 6 30:26 ~167mph
Herman,
It looks like the trans you are contemplating has: 1) a Motorsports (tall) 3.154 1st 2) familiar aftermarket close-ratio 2nd - 5th gears 3) an unfamiliar tall 6th for highway cruising (but with the numbers reversed) |
What makes the trans unusually short is the 8:32 cwp
compared to a motorsports gearbox it is 16% - 17% shorter
True ... it's got quite close 2nd-5th gears. But all Motorsports boxes utilize the 8:32, and 1st still comes out to be a tad taller than the original 1st in the G50/20. What car (type & purpose) are you thinking of installing this into, Herman?
/30, /31, /32 all come w/ 9:31
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-06-2008 at 12:57 PM.. |
Yes, I'm thinking of all the late model Motorsports boxes for early GT3R onward. The 3.154 was considered too tall with the 9:31 R&P and race tires.
The 3.154 x 4.000 equivalent with 3.444 R&P would be 3.66 (original is 3.81). 3.65 is considered by Rothsport to be the perfect replacement 1st gear ratio for street 993s using the G50/20 ... a ratio to be made later this year. |
Just for comparison
My /30 which seems just about perfect for a lightly modded 3.8RS ![]() The g50, Herman is interested in for his stockish 3.6 ![]() If his rev limit were 8k, it would make more sense
Definitely not a good choice for a street 993. The original owner probably had a street legal race car, and ruled his favorite short course.
Thank you both for the info and opinions.
Bill, the graphs are great... I really, really appreciate it. Just a update, I spoke with the seller today and the trans comes from a 1999 Gt3 cup car/factory motorsport, the only year with the shifter rod before the cable shifter. He says all the gear ratios are accurate but 5th and 6th still concerns me, seems like a strange gear sets. The sellers final price is $5700. What do you guys think? Is it better to work with this trans ( all steel syncros) than my stock /20 . My REV limit is not 8000 but even at 6800 the gearing does not look to bad to me ( I have never driven a moded trans). It seems usable but I could be very wrong. 1st-39.4mph 2- 55.3 3-73.2 4-93.3 5-107.3 6-165.9 I also plan to turbo my car so I assume this Gt3 trans gearing would be even worse. So for my street/ few track days a year 993 would you buy the cup car trans or just stick with the stock /20 unit for a while. I really want to start driving this thing in a few weeks. How bad are the brass stock syncros? Do the steel syncros change the feel of the gear shift? Sorry for all the questions. Thanks again |
The seller just called me and all the ratios he gave me are wrong.
Bill, Can I bother you for another gear graph? I can paypal a fee if you like. 1-13/41 2-20/40 3-25/39 4-29/36 5-32/33 6-35/30 Now 4th and 5th seem strange no? |
I think it's a pretty nice trans(very similar to my g50/30), for n/a 993 dual purpose car, as long as it's got a 9:31. W/ an 8:31 it's still going to be extremely short(~145 at the top of 6) for a dual purpose trans.
![]() the turbo guys seem to like taller & fewer gears. steel vs brass maybe a litlle crisper, hard to say comparing new to old. $5700 outright is a great price if it's in good condition w/ all the motorsports parts and still has the motorsports 40/60 lsd also in good condition. Just as an issue of interest to me what is the designation of the trans? G96/92 used in '02 Cups have the same gearing also w/ an 8:32, i'm curious if it's the same trans. here it is w/ the 8:32
Just a second opinion to reinforce what Bill is telling you - it's very short. I have a G50/32 that I ran for the first time a week ago. It is much better than the G50/05 it replaced but I would never want shorter.
Bill: I think you had a typo above, the G50/3x final drive is 9:31 (3.444), not 9:32 (3.555) according to my shop manuals.
Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) |
BTW did you sell the /32 lsd yet? If not I have a proposal for you
Bill: No. Send me a PM with your email address. I had been hoping to sell the LSD with the old transmission, but neither has sold yet.
