Vacuum for 993
i have a problem please help
here it is i did engine swap from 3.2L to 95 993 3.6L with Vram in it, yes the plastic intake was swapped to Vram intake. there are plenty of vacuum hoses, i ckd the usual suspect ckd hard hose under the tunnel, ckd the check valve it is working, there is vacuum, no i did not get vacuum to my brakes there is no suction to the front brake booster. what did i miss? any help is appreciated. thanks
"IGNITION LEFT OF STEERING" Alex |
Here's the v-ram vac schematic
thank you Bill you are the best
