fuel filter help
Okay finished adjusting the valves. I want to replace the fuel filter. Is it as simple as unbolting it or is the thing pressurized? Please help; I looked for a DIY but couldnot find find one.
Spain |
I tried pulling the dme relay and running the fuel out of it. That did not work. I made a huge mess. It is as simple as unbolting the ends and looseneing the clamp. Get a bunch of rags to catch the overflow, and please, do it in a well ventilated area. I had a headache for a day after. Good luck.
1991 C4-edging further away from stock 1972 T-Incoming project |
Here's a good DIY article.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
That's the same one I used. A cup to catch the gas worked like a charm. Just remember to double and triple check several times to make sure there is no leak when and after running the motor...
