-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Phase 7 (http://forums.pelicanparts.com/showthread.php?t=438518)
Bill Verburg 10-30-2008 02:15 PM
Phase 7
Well I've started the ball rolling on Phase 7, which will be to update the rear suspension to RS spec
for reference here is Phase 1
last year in phase 6 I did the front Rs uprights and second GT2 oil cooler
Phase 6
parts ordered so far
993.331.045.80 Kinematic Control Arm x2 RS, top rear
900.067.323.09 M12x1.5x90 hex head bolt x2 K/T inner
993.331.219.01 eccentric washer x2 K/T inner
999.507.384.09 M12x1.5 nut x2 K/T inner
999.084.449.09 VM12x1.5 nut x2 K/T outer
993.331.041.81 A arm /L x1
993.331.042.81 A arm /R x1
900.378.052.09 M12x1.5x80 hex head bolt x2 a/a trailing
999.084.445.09 VM12x1.5 nut x2 a/a trailing
900.378.051.09 M14x1.5x100 bolt x2 a/a leading
900.380.012.09 VM14x1.5 nut x2 a/a leading
900.380.009.09 VM12x1.5 nut x2 a/a ball joint nut
993.331.047.03 Camber control arm 96- x2 not RS specific, top forward
993.331.217.80 Eccentric screw x2 c/l, top forward inner
993.331.219.80 Eccentric washer x2 c/l, top forward inner
999.084.445.09 VM12x1.5 nut x2 c/l, top forward, inner
999.084.449.09 VM12x1.5 nut x2 c/l top forward outer
the difference between the early 993 supension, later 993 suspension and RS is in the stiffness of the bushings, mine will be set up for min kinetic-toe intrusion
The stiffest bushes are used on the RS and can be identified by the green dot, same as used when identifing the RS sway bar bushes
http://forums.pelicanparts.com/uploa...1225401048.jpg
http://forums.pelicanparts.com/uploa...1225401137.jpg
Don Plumley 10-30-2008 03:12 PM
Green (dot) with envy again!
Bill Verburg 10-30-2008 03:24 PM
Says the guy w/ full ERP rear suspension
Don Plumley 10-31-2008 10:19 AM
Yeah, the world's most expensive turnbuckles.
I like where you are going with your approach. Starting to work on my winter punch list as well, but not nearly as in-depth.
lucittm 10-31-2008 01:30 PM
Bill,
Are you, or have you removed the rear wiring harness for the ABS and pad wear sensors? If so, I could use two of the rubber grommets that secure the harness to the chassis as shown below. I cannot find a Porsche P/N in the PET.
Thanks,
Mark
http://forums.pelicanparts.com/uploa...1225484967.jpg
Bill Verburg 10-31-2008 01:53 PM
Originally Posted by lucittm (Post 4273644)
Bill,
Thanks,
Mark
Mine is a 993 and i'm keeping all of those parts
lucittm 10-31-2008 02:13 PM
Bill,
I take it from your answer that the 993 uses the same grommet on the wiring harness. Any thoughts on how to obtain a P/N for the grommet? Is it worth a trip to the dealer with the picture above? Is a Porsche graveyard my only hope?
Thanks,
Mark
Don Plumley 10-31-2008 03:14 PM
Mark I just looked all over the 964 PET and did not see that grommet listed. That does not mean it is not a part, but it could be part of the harness assy.
Don Plumley 10-31-2008 03:17 PM
Look up 964.612.185 - I don't see a picture of it, but this is the rear brake harness, I bet the grommet is part of that...
MyTurbo3.6 10-31-2008 03:33 PM
Grommet is part of the harness...I picked up a used set from a 944, cut them off and added them to my lines...
lucittm 10-31-2008 08:34 PM
Don,
Thanks. (Sorry for the thread hijack) I searched PP for 964-612-185-00 and did see a listing for a "Brake wear harness" for $311.50. I'll keep my eyes open for a used, burnt, or broken one to get a pair of those grommets. Since Turbo3.6 found some on a 944, it seems they are common to several models.
Thanks,
Mark
Bill Verburg 11-03-2008 04:33 AM
This is the target area
http://forums.pelicanparts.com/uploa...1205940042.jpg
http://forums.pelicanparts.com/uploa...1205957019.jpg
http://forums.pelicanparts.com/uploa...1205957037.jpg
Bill Verburg 12-03-2008 04:02 PM
Here it is $2000 worth of 993RS rear suspension
let the games begin..
http://forums.pelicanparts.com/uploa...1228348818.jpg
http://forums.pelicanparts.com/uploa...1228348897.jpg
I cannot believe how light these things are:eek:
bobesser 12-03-2008 06:31 PM
Aside from the harder bushings, is there any difference?
Don Plumley 12-03-2008 06:49 PM
Sweet!
Bill Verburg 12-04-2008 02:45 AM
A friend did this job last year, he couldn't find any geometric difference. As I proceed I'll certainly be looking to see differences but as the fellow that did it already is an extremely meticulus sort, I don't expect to find anything.
Bill Verburg 01-13-2009 10:51 AM
Some more pics of the arms before installation
http://forums.pelicanparts.com/uploa...1231872649.jpg
http://forums.pelicanparts.com/uploa...1231872681.jpg
Bill Verburg 01-13-2009 10:52 AM
None that I can see, but putting them side by side will be the telling test.
The weathers been brutal here, so no progress
Bill Verburg 02-23-2009 01:11 PM
What a long miserable winter:(
More parts
solid rear suspension inner mounts
http://forums.pelicanparts.com/uploa...1235423281.jpg
http://forums.pelicanparts.com/uploa...1235423359.jpg
Upgraded front monoballs & camber plates
http://forums.pelicanparts.com/uploa...1235423404.jpg
http://forums.pelicanparts.com/uploa...1235423443.jpg
Bill Verburg 02-25-2009 02:23 PM
Started the dis-assembly
step 1 drop the rear suspension to replace the side-mounts, 4 bolts( and a few smaller ancillaries and shes down
http://forums.pelicanparts.com/uploa...1235600304.jpg
http://forums.pelicanparts.com/uploa...1235600430.jpg
The bushes on my rubber mounts were corroded to the al. sidemounts some effort was needed to pop them out.,
The new ones slide in easily
http://forums.pelicanparts.com/uploa...1235600597.jpg
http://forums.pelicanparts.com/uploa...1235600627.jpg
