Rear wheel spacers???
I am thinking about adding some rear wheel spacers to my 1991 C2. I just want to fill out the wheel well a little bit (for effect). What is the "ideal" spacer to use? If I go above a certain size I understand I will need to replace the studs - what is the magic #? Are there any "cons" to adding spacers?
Probably there was a previous discussion on this - I am sorry if this is redundant. P.S. - I have stock 16" rims on my car. |
You can add 5mm spacers without changing wheel studs. With 16" wheels, you could use thicker spacers, but you should then get longer studs.
